3 members (Nick in Manitou, Hotrod Lincoln, Shaffer's1950), 119 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
can i assume that i will get approximately 10 more mph if i replace the rear end gears in my 54 1/2 ton pickup with the 3.55 gears that are available in catalogs? (keeping original 3 speed tranny and torque tube etc)
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
http://www.quiknet.com/~ke6vut/rpmcalc.html
Put in all of your figures. It should help you figure out exactly what you will get for your $700 for the new gears and install kit.
I used it for tires.
I have a T-5 on the shelf and am thinking of doing a new driveline, but all of my stuff still works....so for now...I am not fixin it....
2 Offline
The 3.55 is a very good choice. That 235 won't work as hard at highway speeds. I did my 53 and now I can run on the highway at 60 or 65 without any problems.
I got a set of 3.55's from Patrick's way back when they came out (early '90's) and have been very happy with them. Good quality, good directions. Not cheap, but no complaints as I didn't expect something for nothing. I figured they added 7-8 mph at the same rpm. That may not seem like much, but the difference between 55 and 62-63 is more than you think. The cars don't disappear so fast when they burn by you on the interstate. grin
To be long remembered as he's cruising in
The Passing Lane
i know i am looking at a pretty good chunk of money but just not ready to start cutting her up for a sub job etc. but like you all said i would like to get on down the road a little bit without the motor sounding like it is going to jump out from under the hood and 60-65 is lot better than 50-55. thanks again! hope you all have a great holiday season!
No you will not. The rear end gearing of the the half ton up to 54 is 4.10 and there the difference from going to 3.55 is about 10mph. But, the 54 already has 3.90 and the difference is going to be less.
54 3100 with 235
62 flatbed dump C60 with 261
V
V Offline
I have the Patric's gears in the Torque Tube on my '49 1/2 ton , tired 235 and tall (?32"?) radial 16" tires allows me to haul right along @ 65MPH all day , I was clocked at over 75 crossing Death Valley and it still hauls & tows cars just fine .
Do it , you'll like it .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
Before you go to all that trouble, I went to the local tire shops and moved-up to the tallest tire that I could find, and that took my speed up another ten mph. I also moved from a bias to radial with a larger bubble which added to drive comfort and handling...
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
Changed mine last year from 4:11's via Patrick's kit and can be happier.
Here's some shots of the switchover:
http://community.webshots.com/album/105853469Imjqnu
http://community.webshots.com/album/111968325LqgnhX
Craig
