0 members (),
137
0
Mod | | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | I've managed (with lots of WD40) to remove the original brake pulleys on a 41 3/4 ton chevy, I now have them on the bench.
The bolt through the middle appears to be welded to the pulley - but I would have thought it should spin on the bolt when the brake is pulled.
Before I go at it with more WD40 and a hammer could anyone confirm if they are separate items. If they are 'one' then shouldn't there be a lock nut.
Cheers
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | Yes they are separate items. Mine were frozen on my 37 Chevy pickup. I just kept spraying w/PB Blaster for several days. I then held the pulley near the bolt w/vise grips and a socket & rachet on the bolt. It finally broke free. Mine didn't have a lock nut but had lock washer on the nut - don't know if that was original. The bolt shaft is smooth and the pulley spins around it. Hope this helps.
Charles | | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | It does, thanks.
I'll drop it into some release oil and leave it for 24 hrs before trying again.
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Go to Tech Tips, scroll down to Brakes look at the last item | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I see new ones on ebay and I think its Jim Carter thats selling them. Jeff | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I've seen some folks use a pulley from a garage door that is the same as what you're needing. Worth checking out. | | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | Seen that in the tech tips - and may resort to that if I can't get the originals free.
