0 members (), 202 guests, and 7 robots.
Topics128,106
Posts1,056,213
Members48,436
#376223 02/16/2008 8:58 PM
I've managed (with lots of WD40) to remove the original brake pulleys on a 41 3/4 ton chevy, I now have them on the bench.
The bolt through the middle appears to be welded to the pulley - but I would have thought it should spin on the bolt when the brake is pulled.
Before I go at it with more WD40 and a hammer could anyone confirm if they are separate items. If they are 'one' then shouldn't there be a lock nut.
Cheers
For those who believe, no proof is necessary.
For those who don't believe, no proof is possible.
41 Chevy
Yes they are separate items. Mine were frozen on my 37 Chevy pickup. I just kept spraying w/PB Blaster for several days. I then held the pulley near the bolt w/vise grips and a socket & rachet on the bolt. It finally broke free. Mine didn't have a lock nut but had lock washer on the nut - don't know if that was original. The bolt shaft is smooth and the pulley spins around it. Hope this helps.
Charles
1937 Chevy pickup
1952 MGTD
It does, thanks.
I'll drop it into some release oil and leave it for 24 hrs before trying again.
41 Chevy
Go to Tech Tips, scroll down to Brakes look at the last item
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
I see new ones on ebay and I think its Jim Carter thats selling them. Jeff
I've seen some folks use a pulley from a garage door that is the same as what you're needing. Worth checking out.
dj durant
More pix on Flickr
Seen that in the tech tips - and may resort to that if I can't get the originals free.
41 Chevy
