| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | guys, just bought a 54'cabover today and was wondering about brake info,mc bore size, wheel cylinder bore, where to get parts...... as you can tell this will be my first "stock" big bolt and anyone i have ever been around that has been sitting needs a complete brake job to be safe even just to move around the property.any info would be great | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | Got any pictures, of it. For Brake Parts, call Alretta Truck Parts, of Framingham, Ma. Ph. (508)788-9409. Ask, for Geoff. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | Thanks for the photo link. Looks to have potential. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | being new to big bolts are the clutches easy to replace? what is the usual top speed of these beasts. it was running and moving around today but needs brakes as it has sat since 2001. they did have to use a gas can but it's running. hope to have more pic's next week. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The clutch is no different then any other rig, pretty simple. Brakes can be relined, cant remember where in Tacoma relines them, but thats where my FLAPS sent my clutch and pressure plate off out of my COE. Most FLAPS can get you wheel cylinders or kits, and even master cylinder kits. Many of the vendors carry them as well. Your best bet is to look at the wheel and master cylinder where the numbers will be cast into the side of the parts so you know what your dealing with.
Jeff | | |
