| | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | has anyone installed a sumped fuel tank in their truck? I am running EFI and a sumped tank would be best | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Do a search for in tank pump. It's been discussed here.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | If you want a simple approach, pick up the external pump/sump assembly from underneath a VW Fox - 90-93 are good years. Then you can use the tank you have. These units were fed from the low pressure in-tank units that fed carbs. VW didnt want to invest in a new stamping, so they cam up with this external pump/sump The unit is complete, pump, filter, plumbing, plastic reservoir to prevent stalling. The pump is a bosch 4 Bar unit. Good for about 400-450Hp (then it runs out of flow and pressure starts to drop)
If I can find the one in my garage that I pulled off a parts car Fox I had and kept for the Opel project(its in a box, inside another box in a pile of boxes) I will post a pic.
Scott
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I have a late model mustang external pump mounted on the frame rail. works great. I only had to add a return line to the mustang tank I have mounted under the bed. | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | that is what I have been thinking, I have worked on many mustangs and they have been setup like that for years. (external pump) with a pickup in the tank. they seldom have fuel pump problems. I have access to a blazer tank cheap this should work. | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | Look at the late 80's early 90's Suburban/Blazer tanks they used TPI & EFI in them...joe what are the dimensions on those? will they fit? | | |
