2 members (FishinToms53, Hotrod Lincoln), 128 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#374631 02/13/2008 3:37 AM
has anyone installed a sumped fuel tank in their truck? I am running EFI and a sumped tank would be best
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
50adrod #374651 02/13/2008 4:13 AM
Do a search for in tank pump. It's been discussed here.
~Jim
If you want a simple approach, pick up the external pump/sump assembly from underneath a VW Fox - 90-93 are good years. Then you can use the tank you have. These units were fed from the low pressure in-tank units that fed carbs. VW didnt want to invest in a new stamping, so they cam up with this external pump/sump The unit is complete, pump, filter, plumbing, plastic reservoir to prevent stalling. The pump is a bosch 4 Bar unit. Good for about 400-450Hp (then it runs out of flow and pressure starts to drop)
If I can find the one in my garage that I pulled off a parts car Fox I had and kept for the Opel project(its in a box, inside another box in a pile of boxes) I will post a pic.
Scott
I have a late model mustang external pump mounted on the frame rail. works great. I only had to add a return line to the mustang tank I have mounted under the bed.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
wilbur #376227 02/16/2008 9:11 PM
that is what I have been thinking, I have worked on many mustangs and they have been setup like that for years. (external pump) with a pickup in the tank. they seldom have fuel pump problems. I have access to a blazer tank cheap this should work.
#376235 02/16/2008 9:35 PM
Originally Posted by TooMany2count
Look at the late 80's early 90's Suburban/Blazer tanks they used TPI & EFI in them...joe
what are the dimensions on those? will they fit?
