| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | guys does napa or ? sell a carb kit for a carter updraft 2075S? the carb is on a 54' chevy cabover.also where would i find a book to help in the rebuild proceedure. thanks.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The Updraft Carburetor kits, that are available on the market,are very incomplete. The large chain parts stores don't carry them. I got a kit, from a company out of florida, & I can't remember where the other one came from, but I was very disappointed in them. The Original Carter Repair Kits, are what you want. They show up on ebay, from time, to time. Here's a NOS Carter 2075S, on ebay now, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&Item=120203831727 Also check out the parts For Sale section here,. Chevyb, had some NOS Updraft Carb. floats available. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | SBS Tractor has a Zenith carb. for $193.50. ------------- Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Id give 'em a call at The Carburetor Shop.Espescially with all the advice he gives here to help us out. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | By the way any kit should come with the instructions to rebuild these. Also a good maintenence manual for your year should have a pretty good explanantion of how they work and go together.
These updrafts are dirt easy to work on compared to some of the downdrafts. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | These aftermaket kits, are virtually nothing more than a pack of gaskets. The original Carter kits consist of the gaskets, stepup piston, main metering screw, all springs, pump valve,check valve assembly, venttube, accel. pump, etc. Everything, except, the float assembly. I had a case of them at one time, but only have one left, & it's for the Carter Updraft model 447, for '39-'49 Chevy COE's. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | thats what i was worried about, incomplete rebuild kit just having gaskets and nothing else. is their a supplement manual for these carbs? i'm pretty familiar with updraft carbs as i own a NAA ford tractor (53') and a forklift with chrysler ind. flathead and they can really be a pain. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Keep checking ebay. I've seen the Carter Caburetor Repair Manuals, on there also. | | |
