3 members (Otto Skorzeny, dt235sd, Rusted Nut), 80 guests, and 2 robots.
Topics128,048
Posts1,055,664
#365522 01/25/2008 6:56 AM
i am buying a heater\defroster unit from the classic chevy. my question is has anyone purchased one of these,is it hard to install,and does it work ? it is very cold of late in northern california.
Nate b #365545 01/25/2008 10:36 AM
I have one in mine here in PA just doin tests when the truck is warmed up it blows nice hot air !(not road worthy yet)
Installation was very easy , you get a template for your 3 mounting holes and 2 lines ...the switch is very user freindly and the defrost vents mount right up to your dash..only thing with it is that you have to open an shut doors if you want heat or all defrost ...But it is a very simple clean unit .
Tim
1952 Chevy Shortbed
Photos in Photobucket
Apprentice
Apprentice
I installed one of those heaters in my 54, and I am a little disappointed. The problem is that very little air is actually funneled into the defroster vent hoses when the doors on the heater are shut. While I don't drive my truck much when the temps are low enough for the defrost to be needed, if I did, I would be in trouble as I don't think I would have enough air flow through the defrost vents to keep the windshield clear, nor would it keep my feet from freezing if I elected to leave the vent windows open.
The other issue I have is the fan speed. The unit has two speeds, but both seem quite high, resulting in an awful lot of noise, without producing the necessary airflow.....
3100 #367932 01/30/2008 5:40 AM
Don't say it's very cold in S.J., Ca. People east of calif. will think your a baby.
Just giving you a bad time, lived there for 12 yrs. myself.
Cecil....
first let me thank all of the guys on this site for their help. i am not the best restorer but i am learning. the heater unit that i bought works great. i had to drill and file and drill again but it was exciting doing the work myself. the way i mounted it was with one of the doors facing up toward the windows to use in defrost mode. this can be done without the use of hoses. i also changed the generator to an alternor and what a differce. next is a new carb, 2 sinlges and maybe a cam for my 235. if anyone has done a cam and 2 singles carbs let me know and thank you very much for your help.
Moderated by  ndkid275, Phak1
