4 members (Charles in CA, IHPWR, Otto Skorzeny, 1955 1 Series), 155 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#375482 02/15/2008 1:19 AM
Apprentice
Apprentice
I have several big bolts and I never have trouble with anything but the brakes. I need resources for brake parts. I have mainly c60's with vacuum assist systems. My midwest trucks have road salt issues and my southern trucks have wear issues. So either way I have need of sources of obsolete brake parts.
Thanks to all.
Todd
What kind of parts you looking for? Everything is still available and sometimes are on the shelf for my 54 2 ton. CarQuest, NAPA or any other F.L.A.P.S. that's been around a while should be able to get anything you would need for a 60 - 66 era truck.
Our local powertrain store has several hydro-vac booster styles in stock. We also have a brake shop that can reline the shoes. Several machine shops can sleeve wheel cylinders and the cups are always a stock item at parts stores. The only thing that you may need to order would be a master and hoses.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
3B Offline
Hy todds, many brake parts for 60s vintage big bolts are not "obsolete" the parts in some cases were used for many years, and even though the part numbers are different they may be adaptable to the job very easily. Just tell us specifically what you are looking for, and we will try to help.
3B #375594 02/15/2008 5:57 AM
When I tried to get front whel cyn for my 61 4000 series they didn't come up by model, but with the number on the cyn they are available thru NAPA
I got all the parts I needed for my 65 C50 thru a local parts store that has been around for years.(rubber lines-master and wheel cyl.)I got my hydro vac thru napa. I made all new brake lines. Parts are still available.
Apprentice
Apprentice
Thanks a lot. after reading several replies I think my problem is the local stores I've tried. You are all extremely encouraging though. Hate to park my old tandem. When we dig out of the snow and get ready for field work I will post a plee again with descriptions of the actual parts needed. My shop is only heated from April to October when I can open the doors and let the heat in.
The first thing I might need is a vacuum cannister for a 62 C60.
Haven't seen the truck yet.
Thanks again. Todd
im not to sure everything is available you might have trouble finding drums
