3 members (Materman, blanch53, 1 invisible), 125 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#373714 02/11/2008 4:49 AM
Can anybody out there provide me with some photos of how the door stops are supposed to work? I bought replacement door stops and new brackets (that connect to the doors) from Jim Carter's because both of mine were gone when I got the truck. I did a quick test fit and they are extremely tight and the design seems to be missing something. The new metal brackets rub against the metal of the cab/door jam where the come through. Is this correct? Are they supposed to rub and are they supposed to be theat tight?
Any help is greatly appreciated.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
bump....anybody out there able to assist on this one?
Tim Sheridan
Hi,
I have a 41 3/4 ton with working doors. I've responded to your email with pictures of the handbrake parts.
Hopefully these are of use, if not let me know what pictures I am missing.
Cheers
For those who believe, no proof is necessary.
For those who don't believe, no proof is possible.
41 Chevy
Dalbuie #374356 02/12/2008 6:18 PM
I am at the same spot with my '40. The Jim Carter pieces seem to fit very tight. They will definitely chip the paint where they come thru the jambs. Anyone help us out on this ???
Thanks Guys.
1940 Chevy KC 1/2-Ton
Dalbuie #374614 02/13/2008 3:14 AM
Originally Posted by Dalbuie
Hi,
Cheers
This was helpful. It does appear that it is metal to metal contact which would rub the paint. I think the first step is to flatten the new parts to lessen the rubbing. I am also wondering if there was originally some sort of insert that wnet in this area to prevent the metal to metal contact?
Tim Sheridan
Mine is metal to metal contact. I didn't flatten it out, used it the way it came. I keep a light coat of grease on it. That makes a big difference. john.
Yup….Mine are metal to metal too. My ’41 came with only one door stop so I purchased one from Chevy’s of the 40’s. It came with a rubber pad inside of the spring stop to prevent it from collapsing too far. However the rubber pad would not let the metal pass through the opening in the door post without significant force on the door. I removed the rubber pad and now it works fine.
As far as metal to metal, when you think about it the door hinges are the same, steel hinges and steel pin.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #376912 02/18/2008 5:17 PM
Kip mentions my problem. I have one door that works fine and the other closes on a whim - usually when I am in the way. Metal to metal contact as well. The working door has as rubber pad inside the kick paneland drive side nicknamed the "pincher" has none.
Brett
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
