| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Drove my 53 Burban to a friends house to install, the 6 lug disc brake kit,drop axle from CPP, and lowering blocks.Tranny is an 3 speed overdrive from a 60-61 wagon i was told.It always shifted perfect no signs of anything wrong, what so ever.Now i can't get it to go into reverse,all other gear shift perfect. looked at all the linkage no problems,nothing binding anywhere.any suggestions would help. also we did intsall eveything mentioned, That disc brake set up is a pain in the a$$. Thanks in advance Randy (209)329-8844
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The OD system could have an electrical problem which will lock it out of reverse. The last one that I ran into that did that the owner accidently bumped the terminal on the govenor and grounded it out. Take out the inline fuse and take it out of OD. If it works you will need to trouble shoot the OD electrical components. Fred
Note: This unit is designed to prevent the trans from being shifted into reverse while the OD is engaged. The solenoid may also be jammed into the pawl which engages into the blocker ring. You may need to remove the solenoid and check it out.
