| | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | I have a chance to buy a 1988 Isuzu 5 speed tranny and would like to know if this is the same tranny as an S10 ? I want to put it in my '65 Chevy C10 .I tried to pull up the www.inliners.org site as I know they have a t5 page that lists all the tranny's ID numbers , but I couldn't get it to come up ? I have a copy of the list somewhere but I don't know exactly where it is at this moment ? Can anyone tell me if this is the same tranny as an S10 ? Also , is it the one with the integral bellhousing or separate bellhousing ? I need the separate b/housing . All help will be appreciated .
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm relatively sure that it is not the same, speaking as a former but brief owner of a 1988 Isuzu pickup.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Here's The tag #'s from Mongo's Garage. I saved for future reference. Hope it helps you decipher. Dan | | | | | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Didn't Isuzu actually make some of the earlier F-rd Ranger trucks? I would think that it would be more like a Ranger tranny. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | There are some Isuzu transmissions listed on the print out of T-5 transmissions. A quick check of the tag number on the transmission against the list would show if it is a T-5 or not. It is possible it could be a T-5.
Joe :crazy:
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Originally Posted By: 54gmcDidn't Isuzu actually make some of the earlier F-rd Ranger trucks?
I believe that was Mazda. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Even if it is a T-5, it will probably not interchange with the Chev. unless the Isuzu had a Chev. engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | I had a 1991 Isuzu Rodeo with a 3.1 Chev motor T5 and chev. rear end from the factory new! FACT! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I bet it wasn't a Chevy engine, the 3.1 was only made as a front drive engine, never for rear drive. Every Rodeo I've ever seen had an Isuzu engine in it, and a freind of mine that built them never saw any GM engines in the plant, either. They also all used Aisin rearends.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | My 1982 S-10 has a 1.9 liter Isuzu 4 cyl. Not sure how long they had relations. But they were cozy in 82. I would be intrested to know the verdict. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | GM and Isuzu worked together since at least '72, when the LUV came out. Isuzu did provide 4 cylinder engines for the early S10s, in both gas and Deisel. I seem to recall that Isuzu did build CKD Chevrolets and Buicks in Japan since sometime in the mid-20s.
Bill Burmeister | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | See next post...
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | The 88 Isuzu's had 4cyl Isuzu motors (I had one for 13 years), and if I recall correctly, also could be had with the 2.8 liter V6 that GM put in a bunch of different vehicles. I am talking Troopers (SUV's), not pickups. They were badged with a "V6" badge on the back right-hand side of the doors. This may have started in 89, but somewhere in there they had the GM V6's for several years until they restyled the Trooper and Isuzu made or sourced a DOHC V6 for them.
Whether or not the transmissions and engines all had a Chevy bolt-pattern, I have no idea, but I do know they had the GM 2.8 motors for several years.
Oh, GM and Isuzu are still cozy as the original Duramax diesel in GM's heavy duty trucks is an Isuzu designed motor. I think Isuzu may have produced the motors when they first came out, but I don't know if that is still true.
R-Bo
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | If the T-5 doesn't bolt up to your 65 bellhousing, you could use an adapter plate. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | Actually I have seen a few and knew one owner that had one with a factory GM 2.8 V6 in it. Later GM came out with a 3.4 rear wheel drive engine as a replacement. You could put them in Rodeos or early Jeep Cherokee. He had the newer 3.4 installed and it ran like a scaulded hound. You can still buy that engine from Chevrolet. It has 40 more hp and way more torque than the ole' 2.8. They were mainly for carb engines but they told me at the dealer that a cam swap would make it much better for TBI. Otherwise you would have a bit of hesitation when you first take off. Aside from that they ran really well. Almost bought one. His was an automatic and the others were stick except for one. Later they put in their own Isuzu engines in them. The 3.4 rear wheel drive was better than the Isuzu engine. Just some info. Plus all you need would be a set up from a Rodeo or Trooper that had the V6 emblem and had the GM engines in them. | | |
