2 members (Gdads51, 1 invisible),
92
0
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I will be installing a 41 to 46 steering box in my 37 and would like to install a new pitman arm seal before it goes in,where can I get one. Jeff | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jeff,
You probably have a plan in mind, but if the bushing is worn out, the seal will only hold for a short time before it too hits the road. It's only there to keep the lubricant in the box...the bushing holds the sector from wobbling around.
Stuart | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Maybe I should send it out to be rebuilt as I know nothing about it and its probably wore since the box came from the hills of Kentucky. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Jeff:
I just went completely through the one on my ’41. There is really not much to them. Only trick is not loosing some of the balls. The shop manual has a great rebuild description.
The seal you need is a Chicago Rawhide # 11055
| | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | NAPA or any local parts store will have the seal. (CR #11055) Stuart is right, you should pull it apart and at least clean it out and adjust it. They are simple to work on, and getting rebuild kits is pretty easy. Most vender's sell them. You can also go to your local bearing supply house and get what you need for a lot less money. Just take your old bushings and roller balls with you. The gaskets can be made very easy to. You will want to make a new seal for the 3/4" diameter input shaft as well. They are just leather so you cut a new one or just install a o-ring under the cap. It just needs something to keep dirt and water out of the gear box. Joe | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I find the seals in the rebuild kits to be sub-par, to say the least. Original GM seals are still available and are top quality. | | |
