| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 26 | New here and looking for some help. I'm looking at a restored '51 1/2 ton. Question is the bedsides, on the outside of the (lower)bedside I see 2 'dimples'(welds) between the bed post and the front of the fender. Are these welds from the inner bed supports? I think I remember asking I guy at a show once that had a restored original about this and I think he said it was how they were. This is a California truck and I believe it may have the original bedsides. Do most people fill these in?? The truck was restored about 4 years ago. The pictures I have are very clear and the truck looks very straight and clean. I'd attach a picture if I knew how. Any help would be appreciated. Thanks
| | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | Welcome to the best website for your Stovebolt needs. Pictures will be most important. Try an off site photo sharing site to upload and then attach it to your next posting. For help with that there is info at IT Short Bus forum. click here. Stay tuned for responses regarding your question as the folks here are the absolute BEST, anywhere. Once again: Welcome! | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | Wood - I'm not entirely sure I understand your question, but I'll give it a try...
The original angle strips on the inside of the bed are spot welded to the bedsides. There is a spot weld about every 6-inches the entire length of the bed. These welds often appear as a slight dimple from the exterior. When I replaced my bed boards and angle strips, I had to drill out the spot welds to remove the angle strips. Some folks choose to replace the angle strips and BOLT the stips to the bedsides. Others, weld the strips to the bedsides just like the originals. | | | | | Joined: Feb 2008 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 26 | Thanks, that sounds like it makes sense. Most people must fill and smooth these out I guess. It is my understanding that the owner that did the restoration wanted it original in appearance and I believe it to be the original steel body. Thanks for the help.
