| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 42 | Hi Guys I was wondering if any one knows the size of new king pins? I have a 1946 1 1/2 ton. I have to replace the king pins but don't know if I have STD or .010 over or maybe bigger. I can order new ones after I find out. Also does any one know how to tell if my tie rod ends are worn out? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mike Shepard, depending on which model you have and whether or not it has a heavy duty axle, the three possible sizes are 1.109" X 6.34",or 1.109" X 6.75", or .921" X 5.18", hope that helps. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mike Shepard,
For you '46 1 1/2 ton I came up with a pin 6 3/4" X 1 1/8"...don't know if it's correct or not.
I'm not sure on this either, but all the rod ends should be the old style multi-piece adjustable type. Any slop can be adjusted out by adjusting the big plug on the end of the rod...the only caveat would be if the ball was worn square and that would require a replacement.
Stuart | | | | | Joined: Feb 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 42 | Thanks 3B I think they must be standard as they measure .921x5.18 and thanks atomarc i'll try to adjust them. | | |
