4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#373120 02/10/2008 12:18 AM
Hi Guys
I was wondering if any one knows the size of new king pins? I have a 1946 1 1/2 ton. I have to replace the king pins but don't know if I have STD or .010 over or maybe bigger. I can order new ones after I find out. Also does any one know how to tell if my tie rod ends are worn out?
3B Offline
Hy Mike Shepard, depending on which model you have and whether or not it has a heavy duty axle, the three possible sizes are 1.109" X 6.34",or 1.109" X 6.75", or .921" X 5.18", hope that helps.
3B #373169 02/10/2008 2:05 AM
Mike Shepard,
For you '46 1 1/2 ton I came up with a pin 6 3/4" X 1 1/8"...don't know if it's correct or not.
I'm not sure on this either, but all the rod ends should be the old style multi-piece adjustable type. Any slop can be adjusted out by adjusting the big plug on the end of the rod...the only caveat would be if the ball was worn square and that would require a replacement.
Stuart
atomarc #373234 02/10/2008 4:15 AM
Thanks 3B I think they must be standard as they measure .921x5.18 and thanks atomarc i'll try to adjust them.
