3 members (1955 1 Series, TUTS 59, baldeagle), 106 guests, and 2 robots.
Topics128,037
Posts1,055,470
Members48,424
#373108 02/09/2008 11:52 PM
Apprentice
Apprentice
Anyone got any experience with an 8 volt battery in a 6 volt system? If you do and you are using one in your truck can you share your thoughts and tell me where you can buy one for less than an arm and leg. Several old mechanics have advised me to put one in my 47 1/2 ton to improve starting. Appreciate it.
mazzer #373122 02/10/2008 12:25 AM
I'm running an 8 volt battery that was pushed on me by my local parts store. I've had no problems, but the brighter guys will tell you to fix the problems and forget the 8 volt upgrade. Do a search (upper part of this page, right side) on "8 volt battery" and you'll get lots of hits on similar or identical questions.
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Ex Hall Monitor
Ex Hall Monitor
What Organbuilder said. An 8v battery is a bandaid "fix" for other problems.
Tiny #373187 02/10/2008 2:38 AM
Subject has been covered many times, but why not once again. Going to a clean connections, at least 00 battery cables and a good battery, (I am using a 6v Optima battery) and you will not have any starting problems at all. Like what has been mentioned, an 8v battery actually causes more problems than solves them .
1936 GMC T-14 1/2-Ton Pickup
