0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#372107 02/07/2008 11:32 PM
i have a 10 bolt rear end in my truck and it leaks at the left axle and the pinion, could some tell me how to replace these seals, i've never worked on a chevy rear end befor only fords
pushrod #372118 02/07/2008 11:43 PM
not much diff on the pinion,remove nut and flange replace seal tighten nut to about 100ft lbs,,,for the axel you will have to remove rear cover and C clip in diff that retains axel ,,seal is in diff housing for axel...doc
doc41 #372406 02/08/2008 2:32 PM
thank you for the info,,,
pushrod #372416 02/08/2008 2:48 PM
Leaky rear end...Try Depends. grin
Builder #372482 02/08/2008 5:03 PM
do you have to pull the axle? lol
pushrod #372746 02/09/2008 3:05 AM
Yes.
Bill Burmeister
LONGBOX55 #372793 02/09/2008 4:29 AM
Certified Bolt Nut
Certified Bolt Nut
after reading the title of the post, I figured Imodimum AD could fix it..but I see its a different rear end... grin
I'm not sure how to fix a leaky rear end, but I know I would stay close to a bathroom.
U
U Offline
While you are under there diging around.
Check your differential vent.
