5 members (Otto Skorzeny, 1955 1 Series, TexasJim50, Wayne67vert, Rexville48), 123 guests, and 2 robots.
Topics128,141
Posts1,056,488
Members48,441
I
I Offline
Basically i would like to make this as waterproof as a dolphins behind, and yet able to go to places that are sub zero with it. Is there ' the way ' how to insulate a bus professionally with no future worries of mold, condensation, leaks etc ? I,m also putting standard electrical outlets throughout the bus, so a gap of 3 1/2 to 4 inches needs fill. Thanx guys ! Cheerz !
"THE way" it's done professionally is with closed cell polyurethane foam, an expensive alternative that needs to be done professionally and isn't very 'forgiving'
the important points: fully isolate the exterior skin from the interior so there is NO metal that makes continuous contact between the 2 'shells' ... seal the backside of the skin to prevent condensation in the insulated space
I'm in the process of gathering materials for the same job this spring/summer - plan is to cover the inside of the metal skin with Sealgard, a sticky back roll roofing similar to 'peel n seal', to eliminate condensation and add some sound proofing - I'll put cut-to-fit 2x in the metal ribs, isolated from them by the stick on foil backed pipe wrap, and that'll be the attachment point for the interior wood paneling
the insulation material you use can be a variety of things, but the pink fiberglas bats will collect and hold any moisture, so not the ideal, rigid pink is better but fiddly to fit the curved spaces .... what I'll be using is sheeps wool bats [from Alberta], as good an R value as any for about the same price, and good for making sweaters after the bus rots away from around it grin
swing by if you're on the Island
dont use fiberglass bats they turn into a mess i did a metal shop i put plastic against the metal then the closed cell styrofoam you can feel the warmth that it puts out and its water proof i then put plywood and then sheet rock but after the styrofoam you can put what you want it cost some money but you only pay once and it will be done right and last forever good luck i sealed the joints with duct tape
Have you read this posting from another site?
http://www.cardomain.com/ride/340096/5
Its very cool and expensive! Joe
On my bus, I used a spray/brush on ceramic insulation/coating (I think the new commercial name is Lizard Skin) on the inside of the exterior skin.
I then added a layer of the "bubble wrap" type insulation with the foil on both sides. Not the best insulating properties, but it shouldn't be an issue when it comes in contact with moisture from the design of the side windows.
I am also in the process of adding a 1/4" layer of closed cell landau foam on the interior side of the interior skin. It will serve as a padding for the upholstery as well as have some insulating and noise dampening qualities.
Member #719
1940 Chevy School Bus
Imagination is more important than Knowledge - Al Einstein
I
I Offline
Thats a wicked trailer ! Wow,..now thats a rebuild.
I
I Offline
Lizard Skin looks expensive considering it would be covering a bus. Wool batten is $6.50 a pound. Time to raid the piggy bank ! Nothing but the best for my new gal.
Moderated by  ndkid275, Phak1
