2 members (Gdads51, 68ironhead),
174
0
Mod | | | Forums66 Topics128,110 Posts1,056,251 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | I am working on a 46 1/2 ton pickup. It has a 700R4 transmission. I want to instal a transmission mounted shifter that made by Lokar. Has anyone installed one of these.
I also want to install the floor mounted emergency brake. I like the one from Lokar. The cable kit cost more than the brake handle. Any ideas?
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | got both .the tall nostalgia shifter,and the e beake.but i opted for the trans mount vs. the floor mount thought it would be stronger.i have not installed mine yet but the display models looked simple enough..............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have both on my 55,along with a 700R4 tranny. Installation is easy on both ,but just followc the instructions.And yeah they are quite pricey. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | in the gallery there is a pic of My Lokar mounted on my Turbo 350 ..very simple install and very ROCK SOLID ,..you are getting what you payed for !...I love mine. P.S. get the Nostalgia bend it will fit perfect for seat clearance & my body man said he had folks ask him where the Clutch pedal was ??...when my truck was in his shop . | | | | | Joined: Jun 2007 Posts: 49 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 49 | Nice clean installation! What is the manufacturer of your plug wires and plug wire holders? | | | | | Joined: Jul 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 52 | SW_Radial,
With your lokar 350 set up, what does that right side bolt to? The turbo 350 I have at least has no bolts on the right hand side, just pipe plugs.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | the Kit comes with inserts that fit in those blind holes cast in the Trans Body on the right side. Tim | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | http://good-times.webshots.com/photo/2374147040099708909RtRbDt [/quote] Nice clean installation! What is the manufacturer of your plug wires and plug wire holders? [/quote] Plug wires and holders all came with the GM crate engine. I'm sure you can get them at your local dealer.
~Jim
