1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
I am working on a 46 1/2 ton pickup. It has a 700R4 transmission. I want to instal a transmission mounted shifter that made by Lokar. Has anyone installed one of these.
I also want to install the floor mounted emergency brake. I like the one from Lokar. The cable kit cost more than the brake handle. Any ideas?
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
got both .the tall nostalgia shifter,and the e beake.but i opted for the trans mount vs. the floor mount thought it would be stronger.i have not installed mine yet but the display models looked simple enough..............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
I have both on my 55,along with a 700R4 tranny. Installation is easy on both ,but just followc the instructions.And yeah they are quite pricey.
Here's a picture of mine. It's a simple bolt on.
http://good-times.webshots.com/photo/2374147040099708909RtRbDt
~Jim
in the gallery there is a pic of My Lokar mounted on my Turbo 350 ..very simple install and very ROCK SOLID ,..you are getting what you payed for !...I love mine.
P.S. get the Nostalgia bend it will fit perfect for seat clearance & my body man said he had folks ask him where the Clutch pedal was ??...when my truck was in his shop .
1952 Chevy Shortbed
Photos in Photobucket
Nice clean installation! What is the manufacturer of your plug wires and plug wire holders?
V
V Offline
SW_Radial,
With your lokar 350 set up, what does that right side bolt to? The turbo 350 I have at least has no bolts on the right hand side, just pipe plugs.
the Kit comes with inserts that fit in those blind holes cast in the Trans Body on the right side.
Tim
1952 Chevy Shortbed
http://good-times.webshots.com/photo/2374147040099708909RtRbDt [/quote]
Nice clean installation! What is the manufacturer of your plug wires and plug wire holders? [/quote]
Plug wires and holders all came with the GM crate engine. I'm sure you can get them at your local dealer.
~Jim
