1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | howdy, I recently bought some Penrite 1200w for my steering box. Its thick! Are you supposed to use a grease gun to get this stuff in there or is there another trick?
also do I just fill it up or?
thanks! | | | | | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | I use a squeeze bottle - like a catsup picnic bottle with the long nozzle.
Very sticky, but cleans up quick with kerosene.
Just fill to cover moving parts. Don't overfill - it could be forced up steering column.
Jim
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | You might try warming it up so it can flow better. Put in hot water or leave ina sunny window to warm it.
#3716 10/11/2003 11:29 PM | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | thanks for the tips! I just drove to 3 stores and not one of them had one of those squeeze catsup or mustard bottles! all I could find was one of those small hair dye squeeze bottle things. LOL I made a mess but I finally got some in there. Catsup bottle would have worked great maybe I will tip the waitress extra next time I am at a diner and take one home. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yeah , it's pretty hard to get the stuff to flow . That is what helps to stop it leaking out onto the ground  . I jammed a funnel into the filler hole in the s/box and filled the funnel and left it for the day , to gradually seep down into the box. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A disposible grout bag would work well, they are cheap from Lowedepot. A big syringe would also work.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I used a large {60) cc syringe. Worked good but still a messy job. If you can't find a source for one your dentist, or physcian or vet should have one around. | | | | | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | I actually got my squeeze bottle for this from http://www.mcmaster.com/ (Storage - Squeeze Bottles) Jim
Jim
