9 members (artinva, Gdads51, 1955 1 Series, tesa, JW51, Peggy M, VicZ, Ridgeback, 1 invisible), 93 guests, and 0 robots.
Topics128,077
Posts1,055,932
Members48,430
#3713 10/11/2003 3:21 PM
howdy, I recently bought some Penrite 1200w for my steering box. Its thick! Are you supposed to use a grease gun to get this stuff in there or is there another trick?
also do I just fill it up or?
thanks!
#3714 10/11/2003 4:15 PM
I use a squeeze bottle - like a catsup picnic bottle with the long nozzle.
Very sticky, but cleans up quick with kerosene.
Just fill to cover moving parts. Don't overfill - it could be forced up steering column.
Jim
#3715 10/11/2003 5:18 PM
You might try warming it up so it can flow better.
Put in hot water or leave ina sunny window to warm it.
#3716 10/11/2003 11:29 PM
thanks for the tips! I just drove to 3 stores and not one of them had one of those squeeze catsup or mustard bottles! all I could find was one of those small hair dye squeeze bottle things. LOL I made a mess but I finally got some in there. Catsup bottle would have worked great maybe I will tip the waitress extra next time I am at a diner and take one home.
#3717 10/12/2003 3:53 AM
Yeah , it's pretty hard to get the stuff to flow . That is what helps to stop it leaking out onto the ground grin .
I jammed a funnel into the filler hole in the s/box and filled the funnel and left it for the day , to gradually seep down into the box.
#3718 10/13/2003 9:08 PM
A disposible grout bag would work well, they are cheap from Lowedepot. A big syringe would also work.
Paint & Body Shop moderator
#3719 10/14/2003 4:22 PM
I used a large {60) cc syringe. Worked good but still a messy job. If you can't find a source for one your dentist, or physcian or vet should have one around.
#3720 10/15/2003 5:16 PM
I actually got my squeeze bottle for this from http://www.mcmaster.com/ (Storage - Squeeze Bottles)
Jim
Jim
