Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TexasJim50, Peggy M, Woodcmiami, farmallb, WICruiser, 66flea), 45 guests, and 4 robots.
Topics128,010
Posts1,055,299
Members48,419
#37153 12/03/2002 6:09 AM
I'm in the process of swapping out my 216 for a 235 and I noticed that the rear engine mounts (which are the same for both engines) don't appear to bolt the engine down - They are two metal sleeves that "nest" together, with a rubber pad on one of them. The way they are currently installed, the engine can travel upwards, and I'm thinking that on a sever enough bump, the engine could jump out of the lower mount!
Is this the correct way for these to be installed?
46 GMC
#37154 12/03/2002 10:40 PM
There is a bolt running through them to hold them to the crossmember. Trust me, they hold it down- I had a heck of a time getting mine out. The rubber had decayed and the bolt sunk down in.
Paint & Body Shop moderator
#37155 12/04/2002 4:59 AM
Gabi,
Hope I'm not out of line. Your name denotes a GMC. Are you sure you have a 216? Most are 228's and a different size physically than a Chevrolet I6. Just a thought... Good luck !
Thomas Mott
1949 GMC 250
1957 Dodge COE c-700
1959 Chris Craft 17' w/big journal 327 for more power
#37156 12/04/2002 7:22 AM
Thanks for the info - The old engine was probably not the original and the numbers never confirmed it as a 216, but it had all the other tell-tale signs (as best as I could tell). Anyways, the replacement is definately a 235 -
The bell housing off of the 216(?) fits right on to the 235 - therefore using the same engine mounts.
In regards to the bolting down of the mounts, I cannot figure out how to bolt through the two peices. One bolts to the frame and the other to the engine with no way to join them other than one fitting around the other like a 3/4 sleeve.
Actually, What I really need is a picture!
46 GMC
#37157 12/04/2002 11:12 AM
T. Mott,
you are looking at the wonders of a Canadian GMC. They used Chev engines and chassis. The 216 they used looks like a 235 on the outside, small sidecover, larger manifold, but it had the stroke and bore of a 216. I have mine apart right now and I have been coming across all these interesting details!
1951 1 Ton Completed
#37158 12/04/2002 9:16 PM
Gabe, I think you have the b/house mounts setting together on top of frame and not correctly installed. The top of frame has the big part that bolts to side of housing setting right on the x-over inline with holes. The second peice goes underneath and fits into the x-over and bolt goes thru it, has big washer then nut. This way you have rubber on top and bottom. Maybe, I'm thinking of my old Firds, hmmmmm! Some later year 235's needed a slanted x-over and had slanted ears on the b/house to match. The earlier ones had flatter x-over and b/house was straitht up and down. Clear as Mudd? You need to get a shop manual if you don't have one. Should be pix in it of the mounts. Get a Chevy manual if Chev engines in Canadian trucks.
What ever you find, I'm thinking you dont have the mounts on right, or they are bolted up now and need to be seprated and bolted thru the x-over. They ARE bolted down, don't just set there.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#37159 12/05/2002 7:06 AM
It's getting clearer every day - Thanks for the help. The shop manual I have doesn't show anything of the engine mounts, but I've been playing around with the mounts and I'll be able to figure it out.
Thanks for the help
46 GMC
