| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | I plan to use POR15 on the frame and inner fenders of a 51 1T A How much will I need? Is there a reducer for spraying? | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Everything you wanted to know about POR-15 http://www.por15.com/
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | You don't have to put it on thick! With that said ...if it flows good as you put it on you should get two coats. I have been getting two coats on a chssis out of a quart can. With the inner fenders it will probably be close!
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Be VERY careful if you spray POR15 Use the very BEST breather money can buy !!!!!!!!!!!!!!!!!!!!!!
i hand brushed my frame and inner fenders (2 coats on the inners). i have a daily driver (soon), and don't really care to spend big bucks on a pretty frame. also did the rad bracket, lots of small bits, bottoms of fender apron and running boards, front end, clutch and brake arms & tow hitch.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | i hand brushed my frame and inner fenders (2 coats on the inners). i have a daily driver (soon), and don't really care to spend big bucks on a pretty frame. also did the rad bracket, lots of small bits, bottoms of fender apron and running boards, front end, clutch and brake arms & tow hitch. How much did you use? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | wallybody: PLEASE listen to what CarolinesTruck said. IF you spray it be sure to wear the BEST respirator you can get. The POR15 is some good stuff for sure but will coat your lungs like an iron kettle. Even brushing it on it would be wise to wear some sort of mask. Also be sure to wear some VERY OLD clothing.This stuff is tough and is hard to get off...I usually just let it wear off in about 3 weeks! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't forget some gloves! And yes. 100% true about the respirator, especially if you spray. I know about that one firsthand. It's not pleasant at all.
Bill Burmeister | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I agree with brushing, this stuff goes on really thin but it dries vary thick and vary solid. I asked the sale person how much I would need for my truck frame and he said a quart should do the whole thing with two coats. One thing to know,,, When you open the can it is real hard to re seal it after use. I waisted a bit of whatI had because of that so I think it is best to have everything prepped and ready to paint it all at once if possible.
Good luck Ed | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Ed: even instructions on the can say to put some "saran" wrap over the can when closing. I usually on pour out small amounts at a time as it will start to "set" while you are painting it on and then you use more. It wlll also smooth or level out better if what you are brushing on is "fresh". I like the stuff and agree with you in that I like to brush it on. I have stored it for some time and it still be good. My freind stored it for almost a year and its was still good. I do suggest keeping it in a cool dry place and then "warming" it up by letting it sit in the house overnight.
As a footnote: I've mentioned before that I read somewhere that it is good to "blow into the can" of paint ect which replaces the oxygen in the can with the carbon monoxide from your breath which helps keep paint and stuff from drying out. I can't swear by it but I have always done it with paint, varnishes, ect ect and then open it up after long periods of time and it still be good.....so maybe it does at least help?! | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | even instructions on the can say to put some "saran" wrap over the can when closingI high pressured sprayed the entire frame a dozen times before i painted. that was after I used dozens of cans of easy-off oven cleaner and wire brushed the frame ..... everywhere. I can't remember how much I used but if I needed more I'd just go to the store and buy more. i hand painted lots of little things. if you recoat you MUST scotchbrite/sand BEFORE you second coat. I used gloss on most of my bits and frame. the front end was dull black. I used cheap brushes 1'' & 2'' wide, some might not do that but I'm not cleaning good brushes w/ por-15 on them. just pick out the lost bristles or leave them. you really don't see them any way. make SURE what you paint is hidden from the sun as POR15 does NOT like sun and it will turn milky gray on you. good luck and have fun. after all it's just an OLDE TRUCK and nobody cares how it looks they all just wave.
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | POR-15 is different from the traditional enamels, according to thier website it is a moisture cured urethane. Since your breath has a higher moisture content than the ambient air, blowing into a POR-15 can would accelerate it's cure.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | MMMMMmmmm. You just never know what info you learn here! | | |
