7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible),
92
Mod | | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37082 05/19/2005 6:46 PM | Joined: Aug 2004 Posts: 5 Junior Member | | Junior Member Joined: Aug 2004 Posts: 5 | Has anyone used Patricks 2" lowering springs? Does it handle that much better than new stock springs?
Any advice on doing this 2" lowering or not. | | |
#37083 05/19/2005 7:08 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Click on search and type "monoleafs". You'll find all the info and opinions you need.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#37085 05/19/2005 10:41 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I installed a set of patricks lowering springs on the front of my 51,3100,they are four leaf. I also installed new bushings that came with the springs.Also installed a front sway bar.The truck is about two inches lower,and rides real nice ,the sway bar also makes a big difference in handling. old navy 51............ | | |
#37086 05/20/2005 1:11 AM | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | I installed a set of mono-leaf springs on my TF '57. The rears are reverse-eye. It dropped the front about 2.5" and the back about 4.5". I put 2" blocks in the rear to bring it up even. The front slams against the rubber stop when I hit a bump. I think she rides a little stiff for a single leaf. It does look good though. | | |
#37087 05/20/2005 1:32 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i got a set from fatfendered it lowered it nicely but did not give the more car like ride i expected. maybe my fault for wanting to much, i have a nova rearend and open drive shaft.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
