8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible), 99 guests, and 7 robots.
Topics128,264
Posts1,058,358
Members48,485
#370520 02/05/2008 12:50 AM
Working on my 51 and having a situation. Trying to remove the steering colum from the steering box. I have removed the top 4 bolts removed the bottam cap and removed the 4 side bolt tried to drive out that plate only goes half way Still cant sepperate the two What am I doing wrong???
Thanks Robin
Robin71 #370542 02/05/2008 1:20 AM
It doesn't separate there, actually it doesn't separate anywhere. You need to remove the steering box and column as an assembly,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Robin71 #370552 02/05/2008 1:31 AM
3B Offline
Hy Robin71, all I can think of at the moment is that the steering box needs to be centered to be taken apart, possibly one of the sector shaft teeth is hitting the housing and not allowing it to come out. The steering shaft comes out the bottom of the box when the sector shaft is removed, if my memory is correct, hope that helps.
3B #370738 02/05/2008 3:00 PM
Thanks Guys I will remove them as one. After cursing for 2 hours LOL
Robin
