7 members (walter74, KEVINSKI, Hotrod Lincoln, Otto Skorzeny, Shade Baby, msmall, 1 invisible), 92 guests, and 3 robots.
Topics128,269
Posts1,058,401
Members48,485
#370109 02/04/2008 2:10 AM
The wiper buttons over the windshield must be hit each time the wiper is to move in the opposite direction. I put in new vacuum lines, (thought it maybe needed more umph), but no change. Is this normal? It seems odd that the driver would have to constantly change the direction of the wiper.
Also, unlike my 54, the seat in the 46 does not move. It is bolted to the base. Did they move in 46? Perhaps this seat is a replacement, and the person eliminated the track and just bolted this? As always, thank you, Scott
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
Dunno anything 'bout the wipers, but if you cant find a seat with rails, I have a set from a '56 you might be able to adapt to your seat.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
i didnt have to hit my knob to get them to work but had to keep jiggling the the knob and i could rotate the knob almost a whole 360. when i pulled the dash console out to repaint it and the dash i was checking out the wiper linkge from the knob to the wiper motor(sure beats standing on your head). i saw that the knob arm was bent and the grommet that holds the linkage to the knob was missing. i removed the linkage and moved the arm on the wiper motor to the on position and low and behold the wipers work as perfect. luckily i have another truck with the same set up and saw that the knob arm is straight and has a slight twist forward to line up with the wiper motor arm. maybe your fix is just as simple. new grommet should be on the porch when i get home tomorrow
I believe the 56 and the 46 have different cab widths, and you are quite a distance. But thank you for the offer, Scott
51 ashton, The linkage arms you described must be on your 51. The 46 is not under the dash, but is a motor at the top of the windshield (one for each side). Thank you for the input, and I'm glad you got yours to work. Scott
not sure about 46 but on 38 you could lift front edge of seat cushion and adjust it forward and back base stays in place. gas tank under seat.seat split so you could move bottom portion independently on either side seat back one piece no movement.
