2 members (Otto Skorzeny, 1955 1 Series), 116 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
#369720 02/03/2008 1:13 AM
I have a rear end from a 69 c-10 and would like to know what gear ratio I have. ID# on rear end are NF896838, also GM52, and hand stamped on the axle are HB0423W. Any help will really be appreciated.
Squeegebob
My bet is a 3.73
58' 3200 235 3-speed/OD
When all else fail:
Jack up one rear wheel, put the tranny in neutral. With masking tape or chalk, mark the tire, and the driveshaft. Rotate the tire 20 times while counting the number of rotations the driveshaft makes. Divide the driveshaft rotations by 10 and you've gor your gear. (driveshaft turns 41 times, they're 4:11's)
If it's a posi (the one wheel that's jacked up won't turn)jack up both rear wheels, do the drill again only rotate 10 times and divide by 10.
Works every time!!
HB is the code for a 3.07:1 gear,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks guys! It sure is nice to have access to all this knowledge.
Squeegebob
