1 members (Shaffer's1950),
110
7
Mod | | | Forums66 Topics128,076 Posts1,056,009 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 28 Apprentice | | Apprentice Joined: Nov 2007 Posts: 28 | Can it be done? I have a good 305 block and good 350 heads. Can you but this together and will it run right.
If it ain't broke, don't fix it, unless you're me!
1965 SHORT STEP.
| | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | First issue might be that the compression ratio would drop a LOT, since the 350 heads are sized for 350 cubic inches of displacement versus 305. That is a BIG difference, that would drop the compression into the anemic range.
You would have to mill the head a LOT to get that amount of dispplacement difference compensated. I don't know fi you could do that without other problems, like interference between pistons and valves.
I don't know what other issues might be encountered, but I would think the compression ratio loss would be a disqaulifier all by itself.
Jim G | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It depends on which head we're talking about. A lot of them will work. Give us some casting numbers. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I don't know of any 305 heads that weren't also used on 350s not sure but heads with 2.02 valves may hit the edge of the cylider but for the most part small block Chevy heads are small block Chevy heads here is a list of casting numbers for you. http://www.mortec.com/castnum.htm | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Lots of differences in small block Chevy heads. Especially between 305 and 350 heads. Some were open chamber, some were closed. Some may have had 2.02 valves, others 1.94.
A friend of mine put a pair of 305 heads on a 350 once, and I didn't know it until I couldn't help him get it to run correctly.
It would grunt while trying to start and clatter going down the road if you timed it according to specs. If you timed it so it would start, it wouldn't pull itself hardly.
Didn't help that he installed mismatched heads too. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I agree with Grant. Some will interchange depending on the cc volume. There are a several listed on mortec that are shared by 305's & 350's. Not too likely you have a regular set of heads with 2.02 valves. Fred
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the 350 heads have the larger intake valves (194 or 202) they will not work. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2007 Posts: 28 Apprentice | | Apprentice Joined: Nov 2007 Posts: 28 | The heads I have are 1978 truck heads with the 194s. I can get a set of 1976 heavy duty truck heads with small valves (3927185). I was thinking these might work. Just still wondering about CCs and compression. Buddy of mine was saying it might drop compression to 7 or 7.5.
1965 SHORT STEP.
| | | | | Joined: Nov 2007 Posts: 28 Apprentice | | Apprentice Joined: Nov 2007 Posts: 28 | I just looked on the site that heavyhauler sent me and they say the 1976 heavy duty (3927185) heads are 307,327,350 heads 70cc heads. these should work on a 305. Sound right?
1965 SHORT STEP.
| | | | | | Dave Giorgi Unregistered | | Dave Giorgi Unregistered | JUST A NOTE,
I swapped in a 350 to replace the 305 in a 86 Monte carlo. The bolt pattern for the exhaust manifold is different by one bolt of a larger distance on the end of the head of the 305. I could not use the original exhaust manifolds of the 305 and had to go to headers. Just thought you may be able to use that information.
Dave | | | | | Joined: Sep 2007 Posts: 30 New Guy | | New Guy Joined: Sep 2007 Posts: 30 | you will lose a point or so compression with those heads. It's common for the saturday night roundy rounders to put 305 heads on their 350s, because you will get a bit over 10 to 1 CR with a stock dished piston for cheap and if they win their competitors cam buy their engine and all that rules stuff. That's why the above post had so much problem cranking the 350 over... | | |
