2 members (John Dlugos, 1 invisible),
150
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 10 Apprentice | | Apprentice Joined: Mar 2006 Posts: 10 | I have a 57 3200 LB with a V8. The truck is new to me and I have discovered a huge oil leak from the transmission. (I looked for a bullet hole it was dripping so fast)
I will repair but before I do, I am wondering about using a tranny from a newer truck - say a '64. I have heard that the 3 spd tranny is a weak point on these trucks and I thought maybe getting a newer transmission might mitigate the problem.
Anybody else had experience with leaks like this? Comments on the newer transmission?
'57 3200 with V8 and not much else.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not a 'weak point', and I've never experienced severe leaks in the many I've driven - could be the rear seal, but check all the plugs are tight and the speedo cable is on
if you can scrounge up a used one with good gears and no leaks, easier to change than rebuild, and cheaper - newer will work, 64 is identical, and from 68 on they have synchro first, although there you need to get the yoke with it cuz the spline count changed, otherwise the 3 speeds are really the same trans from 55 to 70's or 80's
Bill | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | With the driveshaft pulled you should be able to replace the output shaft seal easily enough. I'd bet a dollar to you dime thats where your leak is at. Most of the experiences I've had with the 3 speeds is that they are bullet proof as long as they are driven with some sense and not made to reach warp speed. Tramp | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Not really a weak point if it lasted all these years and the only problem is a leak. I have owned numerous trucks & cars with that same trans and they work fine as long as you drive it in a normal manner. If it is leaking that bad and it is from the rear it will probably need the rear bushing replaced. It will need to come apart to do that. Fred
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it,s leaking that bad it could be the gasket between the case & rear housing. Check & see if the bolts are loose. I don,t think I would replace it just for a leak. A latter trans will give you linkage problems. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2006 Posts: 10 Apprentice | | Apprentice Joined: Mar 2006 Posts: 10 | Thanks for the thoughs guys. All good... I think I'll keep this one and fix it up. Parts place here I come!
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | What about the seal between the side cover and the case? I think thats the only seal that has been missed. Tramp, I know that my truck won't reach warp speed with its current 3-speed. I think its doing good getting to slightly twisted speed.  | | |
