2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Apprentice
Apprentice
I have a 57 3200 LB with a V8. The truck is new to me and I have discovered a huge oil leak from the transmission. (I looked for a bullet hole it was dripping so fast)
I will repair but before I do, I am wondering about using a tranny from a newer truck - say a '64. I have heard that the 3 spd tranny is a weak point on these trucks and I thought maybe getting a newer transmission might mitigate the problem.
Anybody else had experience with leaks like this?
Comments on the newer transmission?
'57 3200 with V8 and not much else.
not a 'weak point', and I've never experienced severe leaks in the many I've driven - could be the rear seal, but check all the plugs are tight and the speedo cable is on
if you can scrounge up a used one with good gears and no leaks, easier to change than rebuild, and cheaper - newer will work, 64 is identical, and from 68 on they have synchro first, although there you need to get the yoke with it cuz the spline count changed, otherwise the 3 speeds are really the same trans from 55 to 70's or 80's
With the driveshaft pulled you should be able to replace the output shaft seal easily enough. I'd bet a dollar to you dime thats where your leak is at. Most of the experiences I've had with the 3 speeds is that they are bullet proof as long as they are driven with some sense and not made to reach warp speed.
Tramp
dj durant
More pix on Flickr
Not really a weak point if it lasted all these years and the only problem is a leak. I have owned numerous trucks & cars with that same trans and they work fine as long as you drive it in a normal manner. If it is leaking that bad and it is from the rear it will probably need the rear bushing replaced. It will need to come apart to do that.
Fred
Riding in the Passing Lane
If it,s leaking that bad it could be the gasket between the case & rear housing. Check & see if the bolts are loose. I don,t think I would replace it just for a leak. A latter trans will give you linkage problems.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
Thanks for the thoughs guys. All good... I think I'll keep this one and fix it up. Parts place here I come!
What about the seal between the side cover and the case? I think thats the only seal that has been missed.
Tramp, I know that my truck won't reach warp speed with its current 3-speed. I think its doing good getting to slightly twisted speed. grin
