6 members (52Carl, Robert Crandall, Rusted Nut, Shaffer's1950, JW51, FishinToms53), 104 guests, and 2 robots.
Topics128,079
Posts1,056,306
Members48,442
#366431 01/27/2008 2:31 PM
I noticed in the summer that the drivers side of my 53 GMC 9300 1/2 ton was sitting a little lower than the passenger side. I measured it yesterday and the drivers side is 1 1/2" lower both front and rear.
First, is it best to replace the springs or get them reconditioned ?
Second, seeing as it seems that both weak springs are on the same side, should I just do the weak side or both sides ?
There has been some debate on this one. Some people say that a re-arched spring doesn't last. I would think that it would depend on your local choices. If you have a spring service nearby that can make new ones, that may be your best choice. The old truck suppliers can get new originals. There is Bill's Truck in Courtice and Antique Chev in Oakville. We have a good spring guy in Bolton here who I used. He is very reasonable.
1951 1 Ton Completed
I got new springs and U-bolts for my 54 1/2 ton from Eaton Detroit Spring - they were very helpful and I was very pleased with their products. If I remember correctly, they're authorized GM reproductions.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Leo Offline
Moderator
Moderator
You can go to Orillia Spring or to Peterborough, a bit further, to Parry Spring Service. They can re-arch them for you.
I think I will go new if I can. I hope I can get away with just replacing the two weak ones. If I have to replace in pairs,I would have to replace all four.
Dave
Originally Posted by Wolfs53
Dave
I WOULD repalce in pairs. Otherwise, there IS going to be a difference between one side and the other, and that is not good in a suspension system.
Jim G
The place in Bolton usually has a Mack truck or school bus in the works when I go in. It is fascinating to see the spring stock, shelves of bushings and the stout machinery they use to do their work. It seems to be an art and a science at the same time.
Out of curiuosity do you have a side mount spare? I had one on my 53 and the weight of it plus me being solo most of the time in the truck made the truck lean on the driver's side. I ended up putting a leaf (or maybe it was two) in the left rear.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I work not to far from York Spring so maybe I'll ask them today if I get a chance.
I do have a spot for a side mount spare but there is nothing in it. The truck sits off level when nobody is in it.
I was also looking at Bills Truck. He might have a used set available.....I don't know about that though.
Leo Offline
Moderator
Moderator
I have a complete helper spring setup out of my '53. You are welcome to have it, I will not be putting it back in.
