4 members (kbenz, cmayna, Cletus1950, 1955 1 Series), 94 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
Apprentice
Apprentice
1 Offline
I put a 700r4 tranny in my 1951 truck.
Is there any way to use the stock speedo cable?
Is there an adapter? The outside housing works, but the inside doesn't.
If I were to get it adapted would the ratio be close?
3.73 10 bolt rear end, 225/60-15 tires
Give the link below a try it will give you some much needed info.
http://www.purplesagetradingpost.com/sumner/techinfo/techinfo.html#Auto
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
Riding in the Passing Lane
If the trans. has the mech. outlet your cable should hook right up & the speedo should work. After it works compare the odometer reading with the mile markers on the freeway. If it,s not right remove the gear from the adapter that the cable hooks to & get one with more or less teeth accordingly. If it is an electric sender type you will have to do something different. Like get electric custom gauges or a conversion. Both expensive.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
1 Offline
The purplesage link has some excellent info on TV cable. Not that much on speedo. In fact, I wanted to try to do my own TV but Bowtie overdrives has such a nice linkage I went with it. Thanks for the link.
The speedo has the mech. outlet and my outer cable housing hooks right up. I don't think something is right. I thought the cable looked like a D on the end for a 700r4, while mine is a very small square. I went to the junk yard today to find the D shaped end to fit to mine to make it work but when I got under a 3rd gen camaro like where my trans is from I saw it has the small square like mine (after I passed over the late models with elec speedos '95) Did my trans rebuilder put in a different drive gear? Let me hear any possibilities.
If it is different pull the gear out & get one that has the square hole. Then test it like I said in the previous post & get one with the correct amount of teeth.
Apprentice
Apprentice
1 Offline
Turns out it had the square hole, they all have a square hole. When I got mine apart the speedo driven gear was broken at the shaft and not turning. Unfortunantlly I broke the housing sleeve while removing it. I found a website, PATC that had a calculator for the speedo gear that accounted for wheel diameter rear end ratio, and tranny. The only other variable I don't know about is the speedometer ratio. Is it 1000 revolutions per mile? I ordered an aluminum housing sleeve and correct 44T gear so we'll see if I can get it together.
