| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36511 04/06/2003 6:23 AM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | ok I have a stupid question. I just bought a 1950 1/2 ton and I was wondering where's the keyhole for the drivers side door. my other 5 window doesn't have one also. :confused: :confused: :confused:
1950 1/2 ton 3 window
#36512 04/06/2003 6:29 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There aint one. Nobody knows why but there are hundreds of theories. Mine is so you can put the dog in the cab without him walking in the street. Of course you have to train him to unlock your door from the inside.  | | |
#36513 04/06/2003 7:21 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | There was a discussion on here a while back that mentioned there were some states that apparently had laws about entering a vehicle on the street side. Don't know how true that is, but it makes sense from the key standpoint.
On the weird side, my panel truck came with a spare set of doors, and both handles had locks. The whole thing looked factory and untouched, and the lock codes were the same on each cylinder. | | |
#36514 04/06/2003 1:52 PM | Joined: Jan 2003 Posts: 43 Junior Member | | Junior Member Joined: Jan 2003 Posts: 43 | Apparently the practice of having key locks only on the passenger door has been going on for some time. I have a '31 **** Model A, and it only has a key lock on the passenger side. | | |
#36515 04/06/2003 5:22 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1952, the handle changed from turn-down to push-button. The lock was in the button on the passenger side (as in previous years).
Don't know about '52 & '53, but in 1954 there were factory options, #395, that included keyed locks in the push buttons on both doors. The locks were keyed to match the ignition key and the lock on the dispatch box (glove compartment). In addition, another #395 factory option was a matching-key lock for the side-mounted spare wheel (Has anyone seen one of these locks? Please post a picture).
The lock on the rear door of Panel and Carryall Suburban models was keyed to match the ignition key (all years had a turn-down handle with lock in the door, similar to '47.5-'51 driver-compartment passenger-side door lock).
Tim | | |
#36516 04/06/2003 9:45 PM | Joined: Mar 2003 Posts: 18 Member | | Member Joined: Mar 2003 Posts: 18 | I am new to these chevy ad's but for my 53 button handle it looks like I can purchase a set of locked and keyed alike button to have a locking door on both sides. I hope so or is it possible to reverse the bottons and have the lock on the drivers side???????? Thanks E d ke6bnl So. Calif.
1963 econoline, 50 f1 pu, maybe 53 chevy pu, 50 f3 pu, 70 chevy shortbed c10,
#36517 04/06/2003 11:37 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I swapped the lock to the driver's side. Key goes in upside down, but it works fine. I think I may order another lock so I can let passengers in.... Nah.  | | |
#36518 04/07/2003 8:01 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | You can get any push-button lock re-keyed to match, it isn't very expensive. I have already had my two spares changed to match my ignition key, but the locks on the truck don't match the ignition.
On a REALLY weird note, my '54 GMC panel and '55.1 Chevy parts truck use the same ignition key. GM only used 60+ of the available tumbler combinations, but it still seemed like a wild coincidence. | | |
