1 members (dunfire),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 25 Apprentice | | Apprentice Joined: Jan 2008 Posts: 25 | Ok, again I checked the search engine, but didnt find my answer. (Am i not searching right or am I really coming up with original questions! :)=) Or am I the only one here who doesnt know the answer to my questions hehehe
How does an oil bath air filter work, did you have to keep adding and changing out the oil yourself?
What was the engineering mindset behind this type of filtration?
Does everyone/anyone still use theres on there truck?
Theres nothing that can't be done. Say, if "they" can do it, so can I.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 57Rat,
The oil bath filter requires the incoming air to make a drastic 180° turn inside the filter housing. The air can do this, but any particulate matter, anything with weight, keeps going straight..splash!, right into the sticky bowl of oil.
The filter is serviced at regular intervals by dumping the old contaminated oil and refilling with fresh.
Dry filter technology wasn't around in the good old days, and it is still thought that a properly engineered oil bath is superior to a dry filter...as least with some folks.
I don't know who still uses these big old beasts, maybe purists do.
Stuart | | | | | Joined: Jan 2008 Posts: 25 Apprentice | | Apprentice Joined: Jan 2008 Posts: 25 | Hey, thankx for the quick response, I am new to this site, and I am always surprised by how quickly questions get gobbled up and spit back out so quickly! So surprised in fact I sometimes sit and wait for my answer, Im getting spoiled! But I think my wifes getting irritated, hehe
| | | | | Joined: Jan 2008 Posts: 25 Apprentice | | Apprentice Joined: Jan 2008 Posts: 25 | Hey, theres nothing wrong with a purist, Not that you said there was, but there the guys we all hope for when we got the tough questions or need the tuff parts!
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There is a bit more to the operation of the oil bath air cleaner. In addition to what Stuart posted, there also is a "misting" action that is happeneing, caused by the way the air flows throhg the housing. Thsi oil mist also traps dirt, namely the fine particles that do not end up in the pool of oil in the bottom of the housing. Thsi mist is collected on a fine wire mesh located in the housing, then returned to the reservoir, along with the trapped dirt. A modern dry filter may be more efficient at trapping dirt, but an oil bath will not clog up, and properly maintained, are as efficient if not more overall. If you look at them, almost all big rigs still use the oil bath type air cleaner (the big chrome tank located next to the front of the cab) because of the low restriction of that type.
Bill Burmeister | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | There have been some long and heated threads debating which is "best", the oil bath or modern dry element. I'm on the dry element side. It's been a few months since the last blow out. It'll be interesting to see if this becomes another.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I won't say one is necessarily better than the other, alot would depend on what type of use the vehicle sees. For myself, I'm in the middle, as I use K&Ns  .
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Back in the early 1950's, one of the shops in Nashville that was in competition with my father's shop built some Oldsmobile engines for the Daytona race, back when they were still running on the beach. Those engines were equipped with the best oil bath filters they could find, and all of them came back with a noticeable layer of sand in the oil pan. That much had gotten past the filter, and the piston rings. The engines were totally worn out from abrasive damage after 500 miles. I'll stick with my paper filter! Jerry
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | My '58 has 102k miles on it with the original oil bath filter and is still running strong. Of course, I don't race it down the beach. | | | | | | Dave Giorgi Unregistered | | Dave Giorgi Unregistered | Hi 57rat,
Welcome to the site.
I always heard that the oil bath air filteration system was like 95% or 98% efficient. I have always used them especially if I was lucky enough to have one equipped with a new vehicle purchase or found one available for my particular application. The big plus is, they are easy and cheap to maintain and I think they look way too cool. Just my opinion.
If you are thinking of a replacement, spend the extra money and go for the K&N as was mentioned above here already. They are without a doubt among, if not, the best replacements available.
Dave | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The main problem with the paper element type of filter is who and where it is made and the size of the unit. The small "Made in China" element filters and the small diameter chrome holders they make can tend to choke down your engine just enough to not be noticible, but enough to cause your engine to run rich and disrupt the gas milage you expect to have. Eventually the plugs fowl and the truth is known. With a proper oil bath air cleaner, this problem can usually be avoided due to the fact that they are sized correctly and air restriction is not an issue. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I took my oil bath housing to my FLAPS & got a modern full size filter to fit. I couldn't tell you what it's made to fit but I think I have the number in the garage.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Tiny, I would like to see a photo or explanation of your oil bath filter with the dry filter in it. I cannot imagine how you did that! I have heard of people putting a modern day dry filter in the original dry filter housings. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I would like to see it too, Tiny. Another question if you replace the oil bath with a decent paper element type, is there one that looks halfway decent? I really don't like those 6 inch diameter chrome types. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | | Dave Giorgi Unregistered | | Dave Giorgi Unregistered | Bill,
Nice truck...love the junk yard pix.,especially that Detroit diesel!!!
Dave | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I've still got an oil bath on my 216.
I keep it there partially becuase I'm a purist, partially because the way I drive it, heavy dust is generally not an issue, and partially because I like being different and surprising the old guys with it.
If you're racing down the beach, I'd spring for a paper element.
If you're driving it under normal (read: road) conditions, then either should be fine. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Check your e-mail olblu49.
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | | | | Joined: May 2008 Posts: 194 Shop Shark | | Shop Shark Joined: May 2008 Posts: 194 | I read these post about oil bath air filters. I have one for my 283 powered 57 chevy 3100 pickup. I have been afraid to use it much as I had heard once that they are prone to fires.
I did occassionally get a backfire through the carburator (have not noticed it in the last couple years since putting a pertronics in it) so I do worry that it may catch fire. Is there any truth to that rumor?
I have thought about trying to convert it some how to use a paper filter internally. I like the look of the big old oil bath filter but worry about the chance of fire.
As a result I usualy run with a cheep 6 inch filter in place of the big oil bath one.
Any suggestions. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I use a paper air filter that fits perfectly inside the oilbath housing. The paper filter is a "Wix Filters" part number: 42011 There are pictures in my photo link if you are interested in looking at it. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | I still have mine, because I see no reason to replace it. Around here, a lot of the roads are gravel(when I can drive it on the road) and the oil bath air filters were ideal(from what was in the shop manual) for driving on dirt roads. As far as it catching on fire, they are supposed to act as spark arresters. Plus oil doesn't burn fast like gas does. I'd let someone who actually knows what they are talking about explain it though. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | svwilbur, I've driven thousands of miles with oil bath air filters, and I would say that the chance of a fire is minimal, unless you fill the filter with gasoline.
Yessirree, gents, the military M-151 (almost a) Jeep used oil bath air filters at least as late as 1986, and probably later. I think the HMMWV was the first Jeep sized vehicle that used a paper filter, but I never drove one, so they might be oil bath as well.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Most of the farm trucks and farm tractors around here have been using oil bath air cleaners for years. Sure keeps that fine dirt/sand out of the engine. I feel the fire hazard is small.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | From the 1954 Chevrolet Truck Shop Manual: Look at the bottom of this page and on the next one. It explains all about the oil bath air filter, and it says that both models use incorporate flame arresters. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | If you have a Rochester B carburetor get rid of the whole thing (oil filled) as they are too HEAVY and will wreck your carburetor. Go with the early style copper mesh and throw that copper mesh away as it will (in time) break down and go straight into the carburetor. Replace it with a paper cartridge replacement from Napa. UNK.....70 yrs. of experience talking! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | There is nothing wrong with oil bath air cleaners under the hood. However paper air cleaners are easier to service. I have been operating over the road trucks since 1964. Oil bath air cleaners were phased out in the late 60's and early 70's because no matter where they were installed, water would get in them and the oil would emulsify and the level would rise to the point that airflow was greatly restricted. The same thing happens with old farm tractors. If they sit outside in a driving rain, water gets in the air cleaner. The large cans on the side of some conventional trucks are vortex air intakes, not oil bath filters. They are very expensive and see limited use with owner operators who like chrome. Pleated paper filters have been the standard for many years. But under the hood on older vehicles where water is not a problem, it is up to the owner's preference. Maintenance is the key factor in either system | | |
