0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | I'm to the point of lowering the back end of the 57. I'm replacing the stocker with a 10 bolt. It has 3" tubes so I bought 3 1/4" u-bolts at Tractor Supply thinking I needed the room for clearance. Turns out the fit is pretty sloppy. Since the u-bolts will be drawn up tight, will this not be an issue or do I need to exchange them for the 3"ers that I should have bought from the outset? If so, Would it hurt to heat and bend the 3 1/4"ers? Opinions? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would suggest getting the 3" ers. You don't want a sloppy fit, that is for sure. | | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | I heated and bent one to shape and will work, but does the heating diminish the strength of the u-bolt? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | You are looking at a small amount of money to get the right U-bolts for the job. Trying to cut corners in this area puts your whole project at risk. As an example, heating a U-bolt for a muffler clamp is one thing, but heating a U-bolt to hold your rear axle in place is another....be smart and use the right part for the job. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | You're right. Guess I didn't want to go back to the store. Going back now. Thanks for the opinions. | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | And bring a switch back with you for trying to cut corners young man. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | LOL Tramp !...make sure it is from WEEPIN WILLOW !..they have that XTRA STING when properly introduced from say your Mother when properly stressed out !..dont ask how I know this ...lol | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | Talking about U-bolts.. I bought new ones for my 59 Apache (31). Trouble is they are about an inch to short. Turns out someone has added more leafs between the axles and original leafs to gain ride height. I would likle to keep it that way, but that means I have to find longer U-bolts. I can have them made, but do any of you know of a source that have something like this? About an inch longer than stock half ton. I suppose the 3/4 tons had longer bolts?
1959 Apache Fleetside Deluxe
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Rocket , For Sanities sake i would just go to your local Spring place an get what ya EXACTLY need made up , for 1 they will be right the first time and for 2 ya wont have to deal with shippin an NOT bein right for like the 3rd time from orderin over the net . My expeirience with CUSTOM or OUT OF THE ORDINARY on my custom Bolt has always been ..if it isnt stock ..best to go look around to your local shops to have it made for ya ...in the long run it is cheaper an less stressful. Tim P.S. they wil prob. have what ya want hangin on the wall ...my local shop has abought every width an length made up an hangin. | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | The only problem I see on my truck using the 3" U bolts is you have to use bottom plates that are too wide for the spring due to the taper of the frame. Anyone else run into this problem or am I not seeing the correct solution for this? Guess my 49 could be different from the 59. Sorry to invade this post just looked like a good place to ask.
