0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | PO got overspray on the side and rear glass of my 56. What is the best and/or easiest way to remove it? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Jewellers rouge or mag wheel polishing batting works really well and will not scratch the glass. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | How about carefully trying small amounts of acetone on a paper towel and rubbing the paint off. Then go back and use regular glass cleaner for a final cleanup. Just be carefull not to drip any acetone on the body!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | Get a bar of overspray clay at your local auto parts store. It will remove overspray, tree sap,etc. without harming theglass or paint finish. | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | I might add that if you use a razor blade, be sure to round off the sharp corners with sandpaper or you could scratch the glass , which would be considerably worse than overspray! | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I used meguiar's final inspection and some bodymans clay.You can buy it at automotive paint supplies stores.Spray the final inspection on and lightly rub the clay on it.The clay will remove the over spray without harming the underlying surface.You can remove over spray on painted surfaces as well.It works really great.Heres a link to the final inspection. Final Inspection 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I use glass cleaner & a razor blade. The glass cleaner acts like shaving cream. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | I've even used 000 or 0000 steel wool & glass cleaner. Works pretty good & haven't had a problem with scratches. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Just scrape it off with a razor blade fergodzsake... | | | | | Joined: Jan 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 56 | I highly recommend steel wool more than the razor blade ideas. If it won't come off with thinner or the clay bar, steel wool is safer than the razor blade, to you, and the glass. Good luck
You can take the girl off the farm, but you can't take the animals out of her truck. Watch the build of my 1954 Chevy at www.v8tvshow.com | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | we always used lacquer thinner it cleans everything off the glass and chrome trim and rubber parts to | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I use laquer thinner, too. Razor blade for the heavy stuff and next to window frames, though.
Bill Burmeister | | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Just for the record, I went with the mineral Spirits and 0000 steel wool. Worked like a charm! Thanks. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | good for you ,was gettin ready to post i use oooo steel wool on glass and mirror almost daily at my job works like a champ........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Listen to bowtietim on this one. My substance abusing bodyman oversprayed by entire truck when he did his final touchup--clay!!! It took it all off of everything with no damage even to new paint. BTW, it does a a gangbuster of a job removing overspray from plastic eyeglass lenses. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Napalm will do it every time.
~Jim
| | | | | Joined: Jan 2008 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 39 | | | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | Try Goof-Off. I know Lowe's has it (in the paint section). If you can't get that, 3M Adhesive Cleaner is the same thing. It's safe on almost any surface. | | |
