| | | Forums66 Topics128,043 Posts1,055,615 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | I am not having luck with the search . I got a new passenger side mirror and stalk for my '52. I look under the dash in the inside and see 3 holes on the inside.However it looks to me the mirror bracket should be mounted with the holes vertically not horizontally. Any suggestions or pictures would help. Thanks Jeff | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | My mirror bracket has only 2 holes. If I am not mistaken to mount a passenger side mirror you must drill new holes in the cowl. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Here you go Cool Chevy. I found this after I typed mirror in the advanced search and got to the fifth page. Denny Graham wanted to know about it on his '50 if that was the way to do it. Here's another. And another. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | jdl, you are very quick at understanding how this board works. You are putting us older folks to shame!.
coolchevy, The mirror bracket mounts in a very similar fashion to the driver's side. If you were to remove the glove compartment, you would see the reinforcement plate on the inside with the two holes in it. Then, all you need to do is drill two small pilot holes from the inside and then finish the job from the outside in. | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Thanks guys, I took another look and found the other "pilot hole". It's all mounted and looks great. coolchevy | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Thanks, Truckernix, but you are the ones that put me to shame with the information and experience that I will need when I get my truck. Of course, I will get that when I get the truck.  | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | jdl when I was your age I was building mini bikes with Briggs & Stratton engines.You should have seen the drive trains. You'll get the truck .You got the fever. good luck. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Thanks!!!!!!!!  | | |
