4 members (TUTS 59, Jon G, 2-Ton, lumbersawyer), 46 guests, and 3 robots.
Topics128,083
Posts1,056,331
Members48,442
LS1/4L80E swap. These are all motor passes. I have a couple things I need to do and I might be able to get a 11.99 out of it on the motor. It also has a 2 stage N20 kit coming. It might just got 10's..
http://73-ls1.com/63truck/sac_10_27_07_low_res.wmv
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming
1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic
1967 Convert Continental: Stock Cruiser
1 Offline
cool stuff! hit the thrift store and get the cameraman a tri-pod.
If you notice there were 2-3 passes that were not so shakey.. Those were the ones I let the camera man drive and I videoed using the tripod I provided smile But very pleased with what it ran.
Looks like it hooks pretty well, are those DOT race tires?
Those are BFG Drag Radials so it is a DOT tire..
V
V Offline
I have a pair BFG Drag Radials for my vette(extras for track fun) and they are DOT tires. You can drive them from home to a race track and be completely legal.
Apprentice
Apprentice
wow those are good times, I know your using the DR's but im still impressed with your 60'. I see you have a fuel cell back there but what else are you doing to hook up so well? what gears are you running? any estimate of horse power? once again im impressed. I wish mine was running 12's, hell i wish mine was running 15's.
SGT Fraemohs, US ARMY
1964 C-10 short wide
In the video's I have drop spindles in the front with 1" lowering springs. They are way tooo stiff though not allowing the weigh x-fer I want to see.
Shocks are Competition Engineering drag shocks. At the track it didn't make a difference if the fronts were set to 90/10, 80/20 or 60/40 again due to the stiff spring in the front. The rears were set to the 70/30 setting.
The rear tire is a simple BFG drag radial 275/50/15.
The rear gear is a 3.73.
There is a 3,200 stall in the truck.
Truck makes 410rwhp on the motor.
I'm currently swapping front springs to a 14" 450lb spring and will probably use weight jacks if I need to to get the ride height where I want it.
The rear spring will stay but I am going to c-notch the frame so I can put 2" lowering blocks in the rear. I'm also making a new bracket for the front of the lower control arm. It will have 4 holes and allow me to adjust the height of the front mounting point of the control arm.
Right now I figure the trucks instant center of gravity is around 30" With the control arm mounted where it is now, my antisquat numbers are about 80% (20% of the weight x-fer is going in to the springs and causing the rear to squat). By moving the upper hole up 4.5" it moves my A/S to 120%. The rear will now lift under acceleration planting the tires even hard.
Obviously it's dead hooking right now on the motor, but I think it's going to have a problem spinning with the bottle. I'm also swapping to a 4.56 gear and 30" tire.
Plan is to run mid-high 10's on the bottle at 127-130 mph.
Apprentice
Apprentice
Sweet! What is your track weight? Could you list specs on your engine?
'64 C-10 Longbed Fleetside Custom with large window. BRE 383 stroker with Turbo 350.
Sweet I like the use of the Buick wheels and I would leave it in primer gray what a sleeper! Is that Carlsbad your running at it has been a long time so the memory maybe slipping, if it is my old Chevelle has made many a pass there.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Old 73 ,
What did you use for a harness to control the 4L80E ? I'm currently installing a 6.0 Gen III into my 61 Burb 4wd and struggling with a harness and the cost.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
Apprentice
Apprentice
I have alot of questions for you so if you would hit me up some time on yahoo are aol an my screen name is svfd2449 are my cell (540) 244-7511 thanks man an I got a 1963 chevy pickup
Brandon Seal
Dave Giorgi
Unregistered
Dave Giorgi
Unregistered
Super73,
Nice post on the video.
I noticed the time improved with the tailgate down. Does the tailgate cause that much drag or was it something else? Anyway, great job, enjoyed the clip.
Dave
Is that an 1/8th or 1/4 mile time?
Cool footage, Super73! Real impressive times, too!
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
