2 members (joe apple, rfs56trk), 126 guests, and 6 robots.
Topics128,203
Posts1,057,286
Members48,467
#362140 01/18/2008 3:18 AM
I have a 63 and am considering going to a mustang two front. I just recently re-did all the steering components, as well as other things. Here is the full run down:
Upper and lower control arms with New upper / Lower ball joints
Drag link with New inner and outer tie rod ends
Power steering box
3" Drop spindles
5 lug disk brake setup from a later truck (5x5 pattern)
I did not replace the pitman arm nor the actual control arm bushings/shafts.
What do you think all that is worth?
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming
1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic
1967 Convert Continental: Stock Cruiser
I'd suggest staying with the superior truck designed parts already on it. No real need to change it. Since you've already overhauled everything, it should work fine, and will outlast the Mustang parts.
Bill Burmeister
Weight is the main reason. Truck is more of a drag truck than a daily driver. I was thinking about maybe just removing the stock cross member and building a new one. I think that is where most the weight is.
