| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 28 Apprentice | | Apprentice Joined: Nov 2007 Posts: 28 | I have a 250 I6 in my 1965 step. I might put a 350 in it. What do I need for motor mounts? Looks like the mounts from the I6 will bolt to the block of the 350 without the metal brackets that are on the I6. Does this work or do I need something else?
If it ain't broke, don't fix it, unless you're me!
1965 SHORT STEP.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | That works, just remove the 6 cylinder extensions, Scott | | | | | Joined: Nov 2007 Posts: 28 Apprentice | | Apprentice Joined: Nov 2007 Posts: 28 |
1965 SHORT STEP.
