2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
Will the oil pan from an early, pre 1954 235, fit on a later 1959 235?
I scouted around but couldn't find the answer in a Stovebolt search.
Alan
smile Alan
1947 (early) GMC EC-302 Dump Truck
Jimmy
More pix in Photobucket
Pre powerglide will have dipper trays for the babbit rods don't think it will work.
I see, I had forgot about the dripper trays. Could they be removed and still allow for a proper fit?
Alan
smile Alan
Jimmy
The earlier pans have a shorter sump. That doesn't answer your question, but they are different. I've read that the later ones have a better design for the way the oil moves around inside.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Pre-Powerglide? Didn't Powerglide transmissions become available in 1950, using a low-pressure 235 engine (with hydraulic lifters) until 1953?
The pre-1954 truck engine oil pans are different but they might bolt up? The oil-sump comment posted above is important.
Starting in 1955 the pan rail bulges out in the middle on the pass side. 1940-54 are straight down both sides. They will not interchange.
My Blog
