1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Will the oil pan from an early, pre 1954 235, fit on a later 1959 235? I scouted around but couldn't find the answer in a Stovebolt search. Alan | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Pre powerglide will have dipper trays for the babbit rods don't think it will work. | | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | I see, I had forgot about the dripper trays. Could they be removed and still allow for a proper fit? Alan | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | The earlier pans have a shorter sump. That doesn't answer your question, but they are different. I've read that the later ones have a better design for the way the oil moves around inside. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Pre-Powerglide? Didn't Powerglide transmissions become available in 1950, using a low-pressure 235 engine (with hydraulic lifters) until 1953?
The pre-1954 truck engine oil pans are different but they might bolt up? The oil-sump comment posted above is important. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Starting in 1955 the pan rail bulges out in the middle on the pass side. 1940-54 are straight down both sides. They will not interchange.
See the USA in your vintage Chevrolet! My Blog | | |
