0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#360685 01/14/2008 9:01 PM
Apprentice
Apprentice
Just like to say I found a suitable rear end for the
panel project. I wanted a rear of similar width to
the stock with disc brakes, built-in E brakes and
3:42 to 3:73's. I also wanted GM and nothing smaller
than 8.5 10 bolt.
Turns out the Blazer/S10/Sonoma ZR2 off road model(around 96 & up) model had such a rear end. (3:73's) They were a shortened version of the full size pickup. The regular S10 only had a 7.65 10 bolt and was clearly not wide enough. The ZR2 width was 3/4" wider than stock.
The one I found was $560. tax in and in very good shape
including rotors, e-brake etc.
A downside might be the limited slip called Eaton Gov Lock may
be problematic if abused. Probably means staying way from
drag racing and excessive tire spinning.
Works for me!
Good piece of into have. Thanks.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Leo Offline
Moderator
Moderator
I had an open diff sitting around the shop out of my '69 Chevelle. It's within half an inch of being the same width. It's a 10 bolt, live rear end with 3.06:1 ratio. It's not in yet, but I hope to modify the spring brackets to make it work. This unit was behind the 396 so I'm sure it can handle my stovebolt six.
