| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 37 | A while back, I seem to recall someone making reference to using a Dakota front suspension under an A.D. Does this suspension unbolt like the old Aspens and Volaries or was someone using the frame stub and all? I guess I could crawl under and see for myself but this time of the year in Michigan, I would rather just ask. I have a '96 Dakota Ext cab 2 wheel drive for sale for $500.00 and thought that if the front suspension would work under my '53, I would use it and the rear end. As long as I already own the Dakota, I would be able to save a few bucks. Thanks Don
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Well it sounds like a plan to me. I have seen some Dakota's used this way but it's been too long to remember how it was done. My suspicion is that it is welded to the frame and not a bolt on deal. But for $500 bucks I'd go for it. The rear should be about the proper width and you could even use the wheels. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes. it is welded. They're also a real pita to get aligned right because of the upper control arm design. There's also limitations in aftermarket wheels if it's the 6 lug due to the odd bolt circle size.
Bill Burmeister | | |
