2 members (Woodcmiami, baldeagle), 93 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#3595 03/23/2003 4:50 AM
Junior Member
Junior Member
I just put a new thermostat in my 70 chevy,(307) The guy at the auto parts store sold me one with a temperature setting of 195 degrees. I immediately noticed that the temperature gauge was heading much higher than it would with the old thermostat in it. I don't know what type (setting)the thermostat had when I bought the truck. I went back to the store and got one with a temp setting of 160 degrees. Does anyone know if this will solve the problem or will I be making a mistake by putting it in. The truck ran fine before i changed it but I thought I would perform a little preventive maintenance since I didn't know how old the previous one was.
#3596 03/23/2003 5:20 AM
180 DEGREES IS TYPICALLY THE NORM. FOR AN ENGINE OF THAT VINTAGE.160 MAY BE A LITTLE COOL FOR YOUR CLIMATE.BEWARE OF OIL DILUTION.
#3597 03/23/2003 5:29 AM
Try to find a 180 thermostat. If none can be found, I would go with the 160
