| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 18 Junior Member | | Junior Member Joined: Nov 2002 Posts: 18 | I just put a new thermostat in my 70 chevy,(307) The guy at the auto parts store sold me one with a temperature setting of 195 degrees. I immediately noticed that the temperature gauge was heading much higher than it would with the old thermostat in it. I don't know what type (setting)the thermostat had when I bought the truck. I went back to the store and got one with a temp setting of 160 degrees. Does anyone know if this will solve the problem or will I be making a mistake by putting it in. The truck ran fine before i changed it but I thought I would perform a little preventive maintenance since I didn't know how old the previous one was.
Thanks | | | | | Joined: Mar 2003 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 45 | 180 DEGREES IS TYPICALLY THE NORM. FOR AN ENGINE OF THAT VINTAGE.160 MAY BE A LITTLE COOL FOR YOUR CLIMATE.BEWARE OF OIL DILUTION. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Try to find a 180 thermostat. If none can be found, I would go with the 160
