| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 41 | I've seen mention here before about a Clark 5spd tranny. Does the code for the 5spd happen to be Clark 5DD on the ID plate attached to the glove box?
Terry Wofford '52 GMC 3 1/2 Ton '51 GMC 2 1/2 Ton '53 GMC 1 1/2 Ton '53 Chevy 2Ton "If it ain't broke, well give me the keys and I'll be right back!"
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Yep, You'll see a "GMC Service Parts Idetification Plate". attached to the back of any '47-'55 400 series, & larger GMC Truck glove box lid. Stamped to the right of this plate will be, Trans. Make: Clark, Type: 205V, or 207V, Speed 5DD. If it's a overdrive, it may say, Type: 207VO, Speed: 5OD. Got any pictures of your trucks posted anywhere.
| | | | | Joined: May 2005 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 41 | Yeah, it occurred to me this morning that the "DD" probably stood for direct drive. But a 5 spd might be a step up from just the 4. I'll have to look again for the 205 or 207 designation. What's the diff between them anyway?
No, I haven't gotten any pictures yet. I had some developed and placed on a CD rom. Would I be able use those to post somewhere?
TW
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | There was also a Clark model 202 DD, & OD transmission, availble, for these trucks.. The 202, 205, & 207 differed in design, & gear arrangement. You can transfer your pictures, from your computer, to a webshots, or photobucket album. www.webshots.com , & www.photobucket.com .
| | | | | Joined: May 2005 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 41 | Thanks for the info Spanky! I'll try to get the pictures somewhere this weekend. That is if we don't get any more wind tearing roofs off I have to go patch. Sweeping snow off a 9 in 12 pitch roof and still having to wear spikes is not what I had envisioned doing when I grew up!
| | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | I used to have a 49 3600, it had a later 235 in it and someone had installed a Clark 5spd behind it. I never drove this truck, I'd traded a 22magnum rifle for it, but never got time to get it running. Young and dumb I suppose, I let it go for cheap. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I was looking for something else and found this Roadranger site that has lots of info on the Clark transmissions. I know nothing more about it.. http://www.roadranger.com/ecm/groups/public/@pub/@roadranger/documents/content/rr_apmt-0069.pdf
Grigg
