0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#357588 01/07/2008 2:46 PM
What a job. both of the bleeder screws were broke off of the rear wheel cyls. used the PB plaster, heat, drilled out the 1st one and was finally able to get it out with a easy out, not so lucky on the second. easy out reamed the hole so had to go to a bigger one, still no luck finally had to use a drill bit that would meet up with the threads and then use a bottom tap to clean out the rest, took my time to make sure that i did not go all the way down into the seat, cleaned it up good looks like it will work just fine... just wanted to the share the experience
Drive with Pride. mike j
family pic
dakota #357593 01/07/2008 3:22 PM
Ex Hall Monitor
Ex Hall Monitor
Aren't these rusty old cars & trucks fun. grin
Tiny #357626 01/07/2008 4:23 PM
Dakota, you da man! Just shows "it can be done".
Achipmunk #357860 01/08/2008 3:39 AM
Hello Dakota,
I live over the hill to the south of you in Green Valley on the south side of Hwy 44..
What is the truck you are working on? Those bleeders can be some of the biggest pia's on a vehicle.
I haven't had much time to dig into this site, so I may be asking obvious questions. Cool to see a local!
Later---DAC
1970 GMC Jimmy K5
1972 GMC C2500
1955 GMC 100
2006 GMC Yukon Denali
GMCDAC #357880 01/08/2008 4:30 AM
Let me start by saying welcome to the bolt. always glad to see someone from the area join in. lot of info to be had I use the search a lot... the truck I'm working on right now is the 50 3600. for the boy. Again welcome and don't be afraid to ask someone will chim in for you
Alvin i did start to work on it again, you made me feel bad about sitting on my you know what... will try to do more.. as long as its not to cold...
family pic
dakota #357886 01/08/2008 4:37 AM
Mike, I'm sorry blush.....but I promised LaVerne I'd see what I could do to get you out of the house grin
Achipmunk #357895 01/08/2008 4:51 AM
ggggggggggggggeeeeeeeeeeeeee thanks
and by the way tiny nothing like working on the old stuff
family pic
dakota #358866 01/10/2008 6:08 AM
Thanks for the welcome, Dakota.
Got to look at some of your pics thru your profile link and I must say that you have some cool old trucks there. Even the F%&d is OK.
Later---DAC
1970 GMC Jimmy K5
1972 GMC C2500
1955 GMC 100
GMCDAC #358918 01/10/2008 2:04 PM
Geeze Mike, If you would just buy my '53 you wouldn't have this problem.....OK, you probably would but you'd have another truck! grin
Bruce
My Trucks
Stuff I Collect
